Oct 28, 2024 9:51 AM UTC
TGFX Designer 4.24.0 Download Problem
I can't download TGFX Designer 4.24.0. I select it from the drop-down list, confirm the license agreement. Instead of downloading the archive redirects to the page. If you select other versions, the archive is downloaded
Peter BENSCH
Oct 28, 2024 10:00 AM UTC
Welcome @zema___, to the community!
Only previous versions can be found in the drop-down list, the current version can always be found with the pink button ‘Get latest’.
Hope that helps?
/Peter
zema___Author
Oct 28, 2024 10:07 AM UTC
I need the previous version (4.24.0). I'm trying to download it, but it won't download. It looks like a bug on your site. As version 4.23.2 and 4.24.1(latest) are downloaded normally. The problem is only with 4.24.0.
Peter BENSCH
Oct 28, 2024 10:24 AM UTC
Ah, now I understand. I'm currently experiencing the same problem, but it usually goes away after a bit of waiting. Sometimes the server has a hiccup.
I'll move the thread to the right board so that my colleagues can take care of it if necessary.
/Peter
zema___Author
Oct 30, 2024 2:37 PM UTC
Tried it a few times. It doesn't work.
