Tran Minh Cong
Jul 12, 2018 5:02 AM UTC
TFT LCD touch screen mapping by external keypad
Posted on July 12, 2018 at 07:02
Dear every body,
I'm doing project about lcd tft 7inch 800x480 and stm32f746.
Currently, i want use external keypad (or external button), not use touch screen pannel.
Example:
http://hshop.vn/products/ban-phim-ma-tran-mem-4x4
I have 1 button on LCD:
// { BUTTON_CreateIndirect, 'Browse', ID_BUTTON_0, 13, 8, 100, 20, 0, 0x0, 0 },
(x,y) =  (13,8).
width = 100.
height = 20.
=> (x,y) center = (13+100/2 = 63,8+20/2=18).
When 1 keypad or button pressed, i checked that ok.
How to mapping 1 key pressed to WM_NOTIFICATION_CLICKED event of
ID_BUTTON_0 (ID_BUTTON_0 is displayed on LCD)? After that, emwin will do something: show dialog...
Can you tell me solutions, please?
Thank you so much!
#tft-lcd-touch-screen-mapping-by-external-keypad
Vitaliy Chernobay
Senior
Jul 12, 2018 6:31 AM UTC
Posted on July 12, 2018 at 08:31
You can emulate key press with
GUI_TOUCH_StoreStateEx
Tran Minh Cong
Jul 12, 2018 6:40 AM UTC
Posted on July 12, 2018 at 08:40
Dear Vitaliy Chernobay,
Via link project:
en.stm32cubef7\STM32Cube_FW_F7_V1.6.0\Projects\STM32756G_EVAL\Applications\STemWin\STemWin_SampleDem
I modified to my project (not use touch_update), dummy data (Simulation).
Can you check it, please?
int gui_keyboard_update(void) {
static GUI_PID_STATE TS_State = { 0, 0, 0, 0 };
GUI_PID_STATE last_TS_State = { 0, 0, 0, 0 };
static int state = 0;
static uint32_t prev_time = 0;
// typedef struct {
// int x,y;
// U8 Pressed;
// U8 Layer;
// } GUI_PID_STATE;
switch (state) {
case 0:
if (HAL_GetTick() - prev_time > 5000) {//After 5s to dummy press external key.
prev_time = HAL_GetTick();
printf('S0\r\n');
state = 1;
break;
case 1:
TS_State.Pressed = 1;
TS_State.Layer = 0;
TS_State.x = 63;
TS_State.y = 18;
GUI_TOUCH_StoreStateEx(&TS_State);
//GUI_PID_StoreState(&TS_State);
printf('S1\r\n');
state = 2;
break;
case 2:
if (HAL_GetTick() - prev_time > 100) {//hold pressed 100ms
printf('S2\r\n');
state = 3;
break;
case 3:
TS_State.Pressed = 0;
TS_State.Layer = 0;
TS_State.x = 63;
TS_State.y = 18;
printf('S3\r\n');
state = 4;
break;
case 4:
state = 4;
break;
default:
break;
But haven't WM_NOTIFICATION_CLICKED event!
Thank you!
Vitaliy Chernobay
Senior
Jul 12, 2018 8:50 AM UTC
Posted on July 12, 2018 at 08:50
like that example
while(1){
pState.x = 200;
pState.y = 120;
pState.Pressed = 1;
 pState.Layer = 0;
GUI_TOUCH_StoreStateEx(&pState);
GUI_Exec();
GUI_Delay(200);
pState.x = -1;
pState.y = -1;
pState.Pressed = 0;
pState.Layer = 0;
GUI_Exec();
GUI_Delay(200);
Tran Minh Cong
Jul 12, 2018 9:06 AM UTC
Posted on July 12, 2018 at 09:06
Dear you,
I'll try solution that you said.
Thanks.
Tran Minh Cong
Jul 13, 2018 1:16 AM UTC
Posted on July 13, 2018 at 03:16
I tried solution that you said.
It is ok.
Thank you so much!
Tran Minh Cong
Jul 13, 2018 5:04 AM UTC
Posted on July 13, 2018 at 07:04
Currently, I want 4 external button Up, Down, OK, Cancel to select file in USB (only 4 file saved in USB, no folder hold 4 file). These files is showed by TREEVIEW.
0:\
   file1.txt
   file2.txt
   file3.txt
   file4.txt
Up/Down button to up/down file name in list file on TREEVIEW.
Ok button to select file (name of hItem to next funtion).
Can you tell me how to do that, please?
How to get text content in the row?
Thank you!
Vitaliy Chernobay
Senior
Jul 13, 2018 7:37 AM UTC
Posted on July 13, 2018 at 07:37
Publish your project
Tran Minh Cong
Jul 13, 2018 6:27 AM UTC
Posted on July 13, 2018 at 08:27
I can get event ID_BUTTON_0, ID_BUTTON_1, ID_BUTTON_2, ID_BUTTON_3 by external key, show list file , by show_files() function.
Link about WindowDLG_Test.c.
https://drive.google.com/drive/folders/1dHgIe4uFZUElhIBmTC-IFxvM4C0D2oIs?usp=sharing
Please check static void _cbDialog(WM_MESSAGE * pMsg) {}
Thank you so much!
Vitaliy Chernobay
Senior
Jul 13, 2018 9:02 AM UTC
Posted on July 13, 2018 at 09:02
I can not open your
WindowDLG_Test.c.
using the program GUIBuilder.
You must modify this file only insert your code only between
// USER START
.....your code
// USER END
Tran Minh Cong
Jul 13, 2018 7:32 AM UTC
Posted on July 13, 2018 at 09:32
Dear you,
I changed code like that you said but not success.
I updated file WindowDLG.c original, before coding.
Can you check it, please!
Thanks.
Tran Minh Cong
Jul 13, 2018 7:34 AM UTC
Vitaliy Chernobay
Senior
Jul 13, 2018 9:44 AM UTC
Posted on July 13, 2018 at 09:44
I correct your file by add this
// Initialization of 'USB'
hItem = WM_GetDialogItem(pMsg->hWin, ID_TREEVIEW_0);
hTreeItemCur = TREEVIEW_GetItem(hItem, 0, TREEVIEW_GET_LAST);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file1.txt', 0);
TREEVIEW_AttachItem(hItem, hTreeItemNew, hTreeItemCur, TREEVIEW_INSERT_BELOW);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file2.txt', 0);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file3.txt', 0);
hTreeItemNew = TREEVIEW_ITEM_Create(TREEVIEW_ITEM_TYPE_NODE, ' file4.txt', 0);
// Initialization of 'OK'
Tran Minh Cong
Jul 13, 2018 7:51 AM UTC
Posted on July 13, 2018 at 09:51
Oh, many thanks.
Next step, i'm hearing you tell me about:
'Up/Down button to up/down file name in list file on TREEVIEW.
Ok button to select file (name of hItem to next funtion).'
Vitaliy Chernobay
Senior
Jul 13, 2018 10:08 AM UTC
Posted on July 13, 2018 at 10:08
Buttons must emulate pressed on
TREEVIEW area
Vitaliy Chernobay
Senior
Jul 13, 2018 8:11 AM UTC
Posted on July 13, 2018 at 10:11
I would make it easier
I would create three buttons with names file1 file2 file3
& and would emulate their pressing
Tran Minh Cong
Jul 13, 2018 9:04 AM UTC
Posted on July 13, 2018 at 11:04
Dear you,
When you finish code, you please update link for me.
Thank you.
