Feb 2, 2024 5:25 AM UTC
TextArea
How can I get the value from a textArea so I can compare it with this '-' character?
JTP1Best answer
Graduate II
Feb 3, 2024 8:26 AM UTC
Hello
So you mean you want to access single characters of textArea ?
If your textArea has wildcardBuffer, you can simply access those thru array like this:
textArea1Buffer[0]
//or
textArea1Buffer[1]
//or
textArea1Buffer[i]
//etc.
Check your viewBase.hpp to find out your buffer name if needed.
Then, if you are using just predefined text-phrases in your textArea:
// include the Text- IDs
#include <texts/TextKeysAndLanguages.hpp>
// define temp buffer, notice the max lenght
Unicode::UnicodeChar tempTxtBuffer[20];
// print your const text to buffer
Unicode::snprintf(tempTxtBuffer, 20, "%s", TypedText(YOUR_TEXT_ID).getText());
// then access you can access characters thru tempTxtBuffer
If you want to compare hole textArea, then you can use uincode::strncmp:
https://support.touchgfx.com/docs/api/classes/classtouchgfx_1_1_unicode#function-strncmp
Hope this helps
Br JTP
JTP1Best answer
Graduate II
Hello
textArea1Buffer[0]
//or
textArea1Buffer[1]
//or
textArea1Buffer[i]
//etc.
Hope this helps
Br JTP
ferdlfAuthor
Feb 3, 2024 4:40 PM UTC
Thanks man!!, it really helps.
