Bea_12
Mar 17, 2025 8:17 AM UTC
Test application
Hello
So, I want to generate a test application, but I cannot load these on my board. Does that problem is normally because we never can upload a test application or what is the Problem here, I also added some parts to the Test application, but I can still not load up. I think I am a little bit stuck right now. Maybe one can help me. Thanks!
( I am useing the TouchGFX Designer 4.24.0)
    LouisBBest answer
    Mar 17, 2025 9:56 AM UTC
    When you create your project, did you chose the right board ? If you chose simulator it will not work.
    Louis BOUDOST Software Engineer | TouchGFX
    Mar 17, 2025 9:43 AM UTC
    Hello @Bea_12,
    What board did you chose when you create the application ?
    Br,
    Bea_12
    Bea_12Author
    Mar 17, 2025 9:52 AM UTC
    Oh sorry I forgot, I am using the STM32F746G -Discovery Board right now.
    LouisBBest answer
