JLee.32
Tearing effect happens randomly after reboot
STM32H750 with external flash and SDRAM
TouchGFX version: 4.13.0
CubeIDE version: 1.3.0
display size: 480x272(landscape), but I config the display orientation in portrait in TouchGFX
color depth: 24bits
https://drive.google.com/file/d/1zCucWuLi5BSJUm0VCHaRtqnaUQRpIIhy/view?usp=sharing
Please see the video showing the tearing effect. It happens randomly after reboot. If I reboot 100 times, I can see it around 1~3 times. It will keep exist until next reboot.
I also found setVisibile (left top icon) will cause tearing, but setAlpha (middle icon) will not. Could anyone provide some advice for debugging?
ktrofimo
ktrofimoBest answer
Senior III
June 27, 2021
Take a look at the Application note AN4861 "LCD-TFT display controller (LTDC) on STM32 MCUs" - page 52, section 4.5.3 "Optimizing the LTDC framebuffer fetching from SDRAM" (https://www.st.com/resource/en/application_note/dm00287603-lcdtft-display-controller-ltdc-on-stm32-mcus-stmicroelectronics.pdf)
ktrofimo
Senior III
June 26, 2021
I have seen similar problem ​and it looks like performance issue. Try to minimize number of widgets and check will you have this problem again. Also try to optimize your LTDC timings - may be increase FP and BP to give more time to CPU for drawing, increase SDRAM frequency, move second framebuffer to another bank of SDRAM if you did not it yet...
JLee.32
JLee.32Author
@ktrofimo​ Thank you so much for your advice. It seems that moving seoncd framebuffer to second back of SDRAM works. Will do more test to confirm. Any article describe why we need to do the setting this way?
Also, could you check the video and see if you have other suggestion? You can see some dots are blink around the number 5.
https://drive.google.com/file/d/1KbVwsV9UsbBB2MxYsR6UH7YXY0IubCRC/view?usp=sharing
Regards,
Jimmy
ktrofimo
ktrofimoBest answer
Senior III
June 27, 2021
