ferro
Lead
Nov 13, 2023 4:09 PM UTC
Suggestion for Typography/TypographyFontIndex, and this use of struct construct in general
Hi GFX team,
GFX auto generates Typography/TypographyFontIndex structs in "\generated\fonts\include\fonts\ApplicationFontProvider.hpp"
struct Typography
 static const touchgfx::FontId DEFAULT = 0;
Could you consider adding a tag that would alias type of struct members ie:
struct Typography
 using type_t = touchgfx::FontId;
This would allow to write eg funtion with  Typography as a parameter:
void functUsingTypography ( Typography::type_t tpg );
    Nov 14, 2023 1:25 PM UTC
    Hello @ferro ,
    We will consider it for future work, but could you explain what functionality you would like to have that you cannot use touchgfx::FontId or Typography directly?
    Mohammad MORADIST Software Developer | TouchGFX
    Hello @ferro ,
    ferro
    ferroAuthor
    Lead
    Nov 14, 2023 1:55 PM UTC
    Hi Mohammad,
    "could you explain what functionality you would like to have that you cannot use touchgfx::FontId or Typography directly"
    Ah, I see. I must have got something wrong while trying to use Typography as a type. Or there was some scenario where I thought Typography::type_t to be useful. Thanks and sorry for the spam.
    Ferro
    Nov 14, 2023 2:13 PM UTC
    No worries at all :grinning_face:
    Good luck
    Nov 10, 2025 1:38 PM UTC
    This make sense adding a type alias like type_t would make it much easier to write function using the struct members without repeating the underline type . It will improve readability and maintainability .
