JGuo.5
Aug 21, 2024 12:32 PM UTC
Successfully created a project STM32F469I DISCO AU1 but can't import to IAR
When importing the project to IAR, a file STM32F469I-DISCO-REV-AU1.ipcf reported missing.
    Aug 27, 2024 11:13 AM UTC
    Hello @JGuo.5,
    When you say import, you mean you open the .ewv file and tried to build the project ?
    Have you done these steps :
    • Change the tool chain in CubeMX to EWARM
    • Generate code in CubeMX
    • Regenerate code in TouchGFX Designer
    If you follow these steps you should have all the files generated.
    I hope it helps,
    Best Regards,
    Louis BOUDOST Software Engineer | TouchGFX
