NFahi.1
STM32L4S9 MIPI - DSI issue
Hi there. I am using the STM32L4S9ZIY6TR MCU (just because its MIPI-DSI 2 lanes properties) . But when i try to configure the pinout with the ST Cube application, the DSI_MIPI is not selectable. What i am doing wrong?
Thank you so much in advance !
Simon.T
To be able to use the DSI. You need to activate the HSE clock in the RCC
Regards,
Simon
Hello @NFahi.1​ ,
Did you tried to activate the HSE clock as suggested by @Simon.T​  ?
Does it work ? If yes, please mark his reply as Best answer (click on "Select as Best").
Imen
