JWalt.1
STM32H7B3I-DK. Example projects show only a blank screen. If I download the hex file from ST for the built in example a display works fine. Something TouchGFX is doing must be incorrect. I'm not making any changes to the generated code.
Martin KJELDSEN
Principal III
April 6, 2020
Did you do any debugging? Is the application running? Are you hitting setupScreen() in your views?
/Martin
