MCiau.1
Mar 8, 2023 11:11 PM UTC
STM32H7 JPEG Encoding does not work with DMA
I'm trying to run the JPEG_EncodingFromFLASH_DMA example and the HAL_JPEG_GetDataCallback & HAL_JPEG_DataReadyCallback never executed.
If I try the polling method, the process is successful.
I've disabled the D-Cache & I-Cache.
FBLBest answer
Mar 15, 2023 3:20 PM UTC
@MCiau.1​ Hi again,
Could you provide more details where it crashes? Status of JPEG registers after HAL_JPEG_Init(); would help as well.
For a while I thought of another issue. but this example is working fine for me on Discovery H747.
Thank you for your contribution.
Firas
Mar 9, 2023 11:38 PM UTC
Hello @MCiau.1​ and welcome to ST Community
Could you specify the STM32H7 board used? Disco/EVAL?
MCiau.1
MCiau.1Author
Mar 10, 2023 4:20 PM UTC
Hello @F.Belaid​ , thank you for your help.
I'm using the Portenta H7 board which is based on the STM32H747XI MCU.
Do you have any suggestions on how to get JPEG to work with DMA Mode?
Regards!
Mar 13, 2023 8:43 AM UTC
Hello @MCiau.1​,
Issue tracked internally. I will get back to you as soon as possible.
FBLBest answer
@MCiau.1​ Hi again,
Firas
