Karan Kolhe
Dec 3, 2019 7:41 AM UTC
STM32f767Zi freezes when using strings
I am using freeRTOS , there are two threads one is for TouchGFX gui task and other for my main task.
I have given 4096*4 bytes of stack for each task and heap size in freeRTOS config is 65536
Now, when I declare a string controller freezes. I want to use strings to manipulate .Ini file . This looks like a memory overflow or something
Dec 3, 2019 7:56 AM UTC
Perhaps you could use a debugger or something?
Instrument the code, and output useful diagnostics if it gets a Hard Fault or ends up in the Error_Handler routine.​
Ozone
Principal
Dec 3, 2019 7:58 AM UTC
How do you "declare strings" ?
"Freezes" is not very helpful. Use a debugger (or instrumentation) to check what fault is really happening, and where.
Us people on the other end have no magic crystal balls.
