AD�?b
Senior
Dec 18, 2019 7:09 PM UTC
STM32F746GDiscovery, Eclipse, CubeMX 5.4.0, STM32Cube_FW_F7_V1.15.0, TouchGFX 4.12.3
I turn on the periphery in defaukt Mode. I add TouchGX, Display Parallel Interface, I set LSD Reset Pin on PI12. I set TouchGFX. I design in TouchGFX Designer. I generate the code, save and leave TouchGFX. I generate code in CubeMX. There are errors after compilation. Why?
AD�?b
AD�?bAuthor
Senior
Dec 20, 2019 2:44 PM UTC
Thank you for this remark. I know where I stand. I worked on Segger but I came to the conclusion that TouchGFX visually gives a better effect.
