The ToggleButtonTrigger.hpp file is found in Middlewares\ST\touchgfx\framework\include\touchgfx\containers\buttons\ToggleButtonTrigger.hpp
The "When Screen Transition Ends" trigger is the new name for what was previously called "When Screen Entered". This means that whatever you wish to do will start after you have finished going to another screen.
The "When Screen Transition Begins" trigger will trigger an action at the start of the transition from a screen to another.
So the difference is just if you wish to have the action take place before or after the transition has started.
