q123w123e123qweqwe
STM32F746 Custom Board Touch Screen Sync issue
I'm working on a Touch Screen project and using STM32F746 MCU. I have an sync issue I couldn't solved yet. Here is video: https://www.youtube.com/watch?v=0T0yGYekXSE
My LTDC parameters are the same with datasheet I think there is some timing problem but I don't know what to do. Here are datasheet and my LTDC config codes.
Datasheet: https://cdn.ozdisan.com/ETicaret_Dosya/493618_9666178.pdf
LTDC Code:
/* USER CODE END LTDC_Init 1 */
 hltdc.Instance = LTDC;
 hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AH;
 hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AH;
 hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AH;
 hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
 hltdc.Init.HorizontalSync = 0;
 hltdc.Init.VerticalSync = 0;
 hltdc.Init.AccumulatedHBP = 46;
 hltdc.Init.AccumulatedVBP = 23;
 hltdc.Init.AccumulatedActiveW = 846;
 hltdc.Init.AccumulatedActiveH = 503;
 hltdc.Init.TotalWidth = 1200;
 hltdc.Init.TotalHeigh = 650;
 hltdc.Init.Backcolor.Blue = 0;
 hltdc.Init.Backcolor.Green = 0;
 hltdc.Init.Backcolor.Red = 0;
 if (HAL_LTDC_Init(&hltdc) != HAL_OK)
 Error_Handler();
 pLayerCfg.WindowX0 = 0;
 pLayerCfg.WindowX1 = 800;
 pLayerCfg.WindowY0 = 0;
 pLayerCfg.WindowY1 = 480;
 pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
 pLayerCfg.Alpha = 255;
 pLayerCfg.Alpha0 = 0;
 pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
 pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
 pLayerCfg.FBStartAdress = 0xC0000000;
 pLayerCfg.ImageWidth = 800;
 pLayerCfg.ImageHeight = 480;
 pLayerCfg.Backcolor.Blue = 0;
 pLayerCfg.Backcolor.Green = 0;
 pLayerCfg.Backcolor.Red = 0;
MMoon.1
June 8, 2020
Do you mean the flickering of the display?
q123w123e123qweqwe
Yes, the flickering.
MMoon.1
June 9, 2020
Have you checked with a scope that you have the expected timings for pixel clock, vsync, hsync
