prog
STM32F469, STM32F769 MIPI DSI video mode
Hi All,
Does anyone can confirm that is possible to send video signal via B-LCDAD-HDMI1 converter to some monitor with a HDMI connector?
Best Regards
Andrzej
Imen.DBest answer
Hello @prog​ ,
You can refer to the LCD-DSI examples (supported HDMI) available under STM32CubeF7 package, and make required updates according to your needs.
  • \STM32Cube_FW_F7_V1.16.1\Projects\STM32F769I_EVAL\Examples\LCD_DSI\LCD_DSI_VideoMode_DoubleBuffering
  • \STM32Cube_FW_F7_V1.16.1\Projects\STM32F769I_EVAL\Examples\LCD_DSI\LCD_DSI_VideoMode_SingleBuffer
(any examples with USE_LCD_HDMI flag set)
The example provides a description of how to use the embedded LCD DSI controller (using IPs LTDC and DSI Host) to drive the KoD LCD mounted on board or a HDMI monitor connected through the DSI-HDMI bridge board MB1232.A
Hope this helps you! :)
Imen
Imen.DBest answer
Hello @prog​ ,
Imen
prog
progAuthor
Hi Imen,
Thank you for help.
Sorry for late answer because holiday time
Example works very well. i'm adapting now to my application
Andrzej
