Senior
Feb 11, 2026 3:07 PM UTC
STM32 Hardfault Error when calling fillBuffer under TouchGFX.
Hey, I am running into issues with a custom PCB based on STM32H743IIT6.
Using IS42S32400J-6TLI as SDRAM,  with an LCD screen. Using TouchGFX and DMA2D deactivated.
A hard fault is encountered after entering Model:Tick()
Hard Fault Error Detected at:
Debug stack view:
LTDC:
SDRAM - only 16 data bits used:
TouchGFX:
MCU:
Any suggestions what could be causing this Hard Fault error?
AEng7Best answer
Senior
Feb 17, 2026 12:26 PM UTC
This was solved by setting the SDRAM, LTDC, and unlocking the MCU regions appropriately
AEng7Author
Senior
Feb 11, 2026 3:23 PM UTC
Seems to go to
Then BusFault Handler at :
AEng7Author
Senior
Feb 11, 2026 3:59 PM UTC
Applying new MCU settings:
I still get the BusFault_Handler error
AEng7AuthorBest answer
Senior
