Rahimi.Meysam
Feb 15, 2015 7:58 PM UTC
Stemwin
Posted on February 15, 2015 at 20:58
Hi.
I have Littile problem with Stemwin.
I have ported Stemwin on my board(STM32f407). nearly all functions(that i have test up to now) is working well. but when I call GUI_SelectLayer(1), Program locked and go to hard fault. My LCD driver is ST7735 and did not mention about multilayer capability.
when i call GUI_SelectLayer(2) or more larger number program did not locked but new layer also did not activate(I set GUI layers to 10).
i would be thank you if some body help me.
thank you
#stemwin-stm32f407
krunal2411
Feb 16, 2015 12:06 PM UTC
Posted on February 16, 2015 at 13:06
If you are using RTOS with stemwin then try increasing the stack size of that task which calls GUI_SelectLayer() function. This helped with me.
Wood.Andy
Aug 8, 2016 9:55 AM UTC
Posted on August 08, 2016 at 11:55
Hi
I am trying to use ST7735 with STM32F103 and STemWin528 but am not having much success - it hard faults in the library.
Please could you post your config files?
Andy.
