moredatalesscenter
Simulator exits prematurely
  • June 22, 2020
  • 15 replies
  • 2571 views
Hello, if I create a partial project from CubeMX, open it in TouchGFX designer, add a button and run the simulator, nothing happens. The simulator executable is built correctly, but it exits immediately with no errors reported.
Martin KJELDSEN
Principal III
June 22, 2020
Screenshots and logs please :)
moredatalesscenter
Where are the logs located? There's nothing to take a screenshot of.
Martin KJELDSEN
Principal III
June 22, 2020
%APPDATA%/TouchGFX-4.13.0
Does the designer tell you that an error occured ?
moredatalesscenter
The Windows Event Log indicates:-
Faulting application name: simulator.exe, version: 0.0.0.0, time stamp: 0x5ef0b0dc
Faulting module name: dgapi.dll, version: 7.5.2.54, time stamp: 0x5d7fb4a8
Exception code: 0xc0000005
Fault offset: 0x00030cad
Faulting process id: 0x7f10
Faulting application start time: 0x01d648985da4ed13
Faulting application path: Src\build\bin\simulator.exe
Faulting module path: c:\windows\system32\dgapi.dll
Report Id: c5223111-826e-469d-9052-a9de149abf38
Faulting package full name:
Faulting package-relative application ID:
Martin KJELDSEN
Principal III
June 22, 2020
Windows version?
moredatalesscenter
Windows 10. No error reported by designer. The log suggests a problem downloading a package. Is there a way to specify proxy server configuration?
Martin KJELDSEN
Principal III
June 22, 2020
I've never seen this issue before but i'm seeing a lot of activity on various sites about generally faulting dgapi.dll in Windows.
Martin KJELDSEN
Principal III
June 22, 2020
Designer uses the system proxy information, and that may be a blocker for downloading packages - BUT, it should not be a problem here if you're already at the compiling stage. You could try running the simulator outside of the designer.
Go to the application folder from a TouchGFX Environment and type
make -f simulator/gcc/Makefile
./build/bin/simulator.exe
See if you get the same error.
moredatalesscenter
The simulator runs fine on my personal laptop which does not have dgapi.dll. This is on all our corporate machines and cannot be removed - is there any way around it?
Building outside Designer is not working:-
make.exe -f simulator/gcc/Makefile
process_begin: CreateProcess(NULL, ruby ../Middlewares/ST/touchgfx/framework/tools/textconvert/main.rb assets/texts/texts.xlsx ../Middlewares/ST/touchgfx/framework/tools/fontconvert/build/win/fontconvert.out generated/fonts generated/texts assets/fonts ., ...) failed.
make (e=2): The system cannot find the file specified.
generated/simulator/gcc/Makefile:219: recipe for target 'texts' failed
make[1]: *** [texts] Error 2
simulator/gcc/Makefile:32: recipe for target 'all' failed
make: *** [all] Error 2
moredatalesscenter
Could you help with other issues our UI engineer has found:-
  1. Cannot export screens as PNG files.
  2. Can simulator rebuild time be optimised?
  3. Can’t add or select already installed font Noto Sans for text typography.
  4. Clickable items have to be buttons. Want to be able to click on text that doesn’t have a border.
Romain DIELEMAN
What do you mean by export screens as PNG files? What are you aiming to do? Like a screenshot?
For the font issue, what did you try? Where did you "install it"? The documentation might help you handle fonts and textArea widgets..
Anything drawn can be clickable. Have a look at how handleClickEvent works, or at the ClickListener mixin class.
/Romain
moredatalesscenter
Hi Romain,
1. Yes, for a screenshot of each screen design
3. New OTF fonts installed and useable in other Windows applications. It looks like you only support TTF fonts, which is a showstopper for me.
4. Thanks, will try that
