Ezgi
Mar 22, 2021 2:22 PM UTC
Shape animation
I have a hexagon shape. I want to move (40,0) to (80,0), (0,0) to (40,0), (40,80) to (0,80), (80,80) to (40,80) and I want to move them back. What should be the condition? I gave a try but I couldn't see any move.
Here is my shape;
shape1.setPosition(111, 89, 80, 80);
 shape1.setOrigin(0.000f, 0.000f);
 shape1.setScale(1.000f, 1.000f);
 shape1.setAngle(0.000f);
 shape1Painter.setColor(touchgfx::Color::getColorFrom24BitRGB(122, 51, 51));
 shape1.setPainter(shape1Painter);
 const touchgfx::AbstractShape::ShapePoint<float> shape1Points[6] = { { 80.000f, 40.000f }, { 80.000f, 80.000f }, { 40.000f, 80.000f }, { 0.000f, 40.000f }, { 0.000f, 0.000f }, { 40.000f, 0.000f } };
 shape1.setShape(shape1Points);
and the animation in handleTickEvent ;
CWRUtil::Q5 currentX, currentY;
	shape1.invalidate();
	shape1.getCornerX(5) = currentX;
	shape1.getCornerY(5) = currentY;
	if (currentX < shape1.getCornerX(1))
	 shapeXChangeFactor = CWRUtil::Q5(80);
	else if (currentX == shape1.getCornerX(1))
		shapeXChangeFactor = CWRUtil::Q5(-80);
	currentX = currentX + shapeXChangeFactor;
	shape1.setCorner(4, currentX, currentY);
Alexandre RENOUX
Alexandre RENOUXBest answer
Mar 24, 2021 12:25 AM UTC
Hi Ezgi,
There are potentially 2 issues in your code.
  • To update a shape, you first need to call updateAbstractShapeCache(). You can find this information in the description of the setCorner() function in AbstractShape.hpp. Here is a extract :
 * Sets one of the points (a corner) of the shape in CWRUtil::Q5 format.
 * @param i Zero-based index of the corner.
 * @param x The x coordinate in CWRUtil::Q5 format.
 * @param y The y coordinate in CWRUtil::Q5 format.
 * @see updateAbstractShapeCache
 * @note Remember to call updateAbstractShapeCache() after calling setCorner one or more times,
 * to make sure that the cached outline of the shape is correct.
 virtual void setCorner(int i, CWRUtil::Q5 x, CWRUtil::Q5 y) = 0;
  • The second point is that your shape is probably using floats so it will still not work even if the first point is correct. You need to use toQ5<float>.
So here is a code example you can base yourself on :
void Screen1View::changeShape()
 if(changed)
 //go back to normal
 changed = false;
 shape1.setCorner(5, CWRUtil::toQ5<float>(40.000f), CWRUtil::toQ5<float>(0.000f));
 else
 //do the change
 shape1.setCorner(5, CWRUtil::toQ5<float>(80.000f), CWRUtil::toQ5<float>(0.000f));
 changed = true;
 shape1.updateAbstractShapeCache();
When your question is answered, please close this topic by choosing Select as Best.
/Alexandre
MM..1
Mar 22, 2021 4:57 PM UTC
I mean Shapes not use invalidate for change. And you dont show code where you create shape1 and add to screen...
Ezgi
EzgiAuthor
Mar 23, 2021 6:29 AM UTC
The shape is declared in Base and handleTickEvent is in View.cpp. When I was writing the handleTickEvent, I took a look at the Line and Circle example.
Alexandre RENOUX
Hi Ezgi,
 if(changed)
 //go back to normal
 changed = false;
 else
 //do the change
 changed = true;
/Alexandre
