MMerc.1
Mar 12, 2020 10:48 AM UTC
Set widget visible doesn't work properly
I have a problem when I want to make a widget visible.
This code works :
myStructure test;
widget.setVisible(test.state); // test.state = bool
widget.invalidate();
But this code doesn't work :
Container widget;
myStructure test;
switch (index)
case 0:
 widget = myWidget1;
 break;
Do you have any idea why the second code doesn't work ?
Martin KJELDSEN
Principal III
Mar 13, 2020 12:15 PM UTC
Are you hitting case 0? And is test.state what you think it is when you hit setVisible()?
/Martin
