JReed.1856
Nov 25, 2019 5:30 PM UTC
Set Text without designer
Is it possible to create a Text without ueing the Designer first? Seems like everything has to be done through the Text Manager.​
Martin KJELDSEN
Principal III
Dec 2, 2019 9:00 AM UTC
getSolidRect() is not what you think, i think. It returns the largest possible rectangle that is guaranteed to be solid.
Please use:
 * @fn const Rect& Drawable::getRect() const
 * @brief Gets the rectangle this Drawable covers.
 * Gets the rectangle this Drawable covers, in coordinates relative to its parent.
 * @return The rectangle this Drawable covers expressed in coordinates relative to its
 * parent.
 const Rect& getRect() const
 return rect;
JReed.1856
Dec 2, 2019 10:08 AM UTC
for some reason I can't call this on xDivText, xDivText.getRect() in the debugger doesn't work, while xDivText.getTypedText() for example works
Martin KJELDSEN
Principal III
Dec 2, 2019 10:20 AM UTC
Just inspect xFivText after calling resizeToCurrentText() and find the rect member.
/Martin
