Senior III
Apr 16, 2025 10:11 AM UTC
sending a callback from a button inside a container (wheel item) to the view
I have a scroll wheel languageSelectorWheel with several items. Every item is a container languageSelectorItem
On the container I have a toggle button. When I click any toggle button, I want to send a trigger on the view of the scroll wheel to execute a function.
On the toggle button I have added an interaction onClick via TouchGFX that emits the trigger languageChanged. The trigger is set on the languageSelectorItem container
On the view where the languageSelectorWheel is added, I have set the callback
void languageSettingsView::languageChanged()
Unfortunatly, it seems it is not called when i toggle the button (settings a breakpoint on the line that call
emitLanguageChangedCallback(); in languageSelectorBase where void languageSelectorBase::buttonCallbackHandler(const touchgfx::AbstractButton& src) is defined enters)
My thought is that because the trigger is set on the container, it won't be passed to the view
nico23Best answer
Senior III
Apr 17, 2025 6:37 AM UTC
Ok so I figure it out. I set a trigger on the container that returns its index
On the interactions I have added a button click that both call a function and executes the trigger
languageItem.hpp (container)
Here you must register the trigger
 void setLanguageSelectedCallback(touchgfx::GenericCallback<const int16_t>& callback)
 languageSelectedCallback = &callback;
protected:
 int16_t itemNumber;
 touchgfx::GenericCallback<const int16_t>* languageSelectedCallback;
languageItem.cpp (container)
here you execute the callback
void languageItem::buttonClicked()
 // Call the callback when the button is clicked, passing the item number
 if (languageSelectedCallback && languageSelectedCallback->isValid())
 languageSelectedCallback->execute(itemNumber);
languageSettingsView.hpp
Here you register the callback from the container
protected:
 * Callback Declarations
 touchgfx::Callback<languageSettingsView, const int16_t> languageItemLanguageSelectedCallback;
 * Callback Handler Declarations
 void languageItemLanguageSelectedCallbackHandler(const int16_t itemIndex);
languageSettingsView.cpp (view)
Finally in the view you can initialize all the callback, one for each element of the wheel
languageSettingsView::languageSettingsView():
 languageItemLanguageSelectedCallback(this, &languageSettingsView::languageItemLanguageSelectedCallbackHandler)
 for (int i = 0; i < languageSelectorScrollListItems.getNumberOfDrawables(); i++)
 { languageSelectorScrollListItems[i].setLanguageSelectedCallback(languageItemLanguageSelectedCallback);
And then you can use the callback on the View to react according to the index
void languageSettingsView::languageItemLanguageSelectedCallbackHandler(const int16_t itemIndex)
Clearly on the View you need a function that set the itemNumber, something like
void languageSettingsView::languageSelectorScrollUpdateItem(languageItem& item, int16_t itemIndex)
 item.setItemNumber(itemIndex);
Where the setItemNumber function must be added to the container
nico23AuthorBest answer
Senior III
protected:
 int16_t itemNumber;
protected:
