ScrollWhell - I can't select first item
I scroll ScrollWheel to first item, but when I release finger, scrolwheel scrolls to second item automatically.
How to solve?
Alexandre RENOUX
May 25, 2021
Hello EEuge,
Could you try to see if the solution of this post helps you ?
If not, could you elaborate your issue ? (Setup info, Video, UI code, etc.) Does it happen also on the simulator ?
/Alexandre
