IMirz.1
September 1, 2021
ScrollList within ScrollableContainer
I have a ScrollList at the end of a ScrollableContainer. If I scroll down the ScrollableContainer to the ScrollList, the items in the ScrollList are not scrollable.
However, if I place the ScrollList out of the scrollablecontainer, the scrolllist items are scrollable correctly. Can we not place a ScrollList withing a ScrollableContainer? or am I missing some required step?
Thanks very much for responding.
ktrofimo
Senior III
September 1, 2021
This is a problem of priority - what container should react on scroll gesture. By default all your gestures are taken by the ScrollableContainer and it doesn't pass them down to SrollList.
If you have two widgets: one scrolled vertically, another - horizontally, then you can write code (Google for examples, I have seen some)​ that can decide what gesture it was and send it to the appropriate widget.
But in your case both scrolling are vertical how wolud you decide what control ​should take control? Try to modify example code and see how it goes.
