apll
Scroll list add/remove
  • May 3, 2019
  • 13 replies
  • 3426 views
Hi everyone,
i would remove or add a object in a scroll list
I try to use
paramScroll.remove(*paramScrollListItems.getDrawable(0));
paramScroll.add(*paramScrollListItems.getDrawable(5));
but it don't work.
paramScrollListItems is a DrawableListItems.
How can i do this function in a scroll list?
Martin KJELDSEN
Principal III
May 7, 2019
Hi @Community member​,
Have you read this article on Scroll List? https://touchgfx.zendesk.com/hc/en-us/articles/360018095032-Scroll-List
/Martin
apll
apllAuthor
Yes, i read.
So if i want remove/add an object i must use the callback is invoked when an item has been clicked?
apll
apllAuthor
This is max number of object in my list
paramScroll.setNumberOfItems(11);
instead this is the function linked with item -> updateItemCallback
paramScroll.setDrawables(paramScrollListItems, updateItemCallback);
i override updateItemCallback that it is called every time change sometime but i don't understand how i can add/remove object...
Can you write an example?
Martin KJELDSEN
Principal III
May 16, 2019
Please check out the ScrollableList and Wheel example from within the designer. You'll see examples of how to set the update-item-callbacks in the baseclass and how to go about their implementation.
Hope that helps,
Martin
apll
apllAuthor
Hi Martin,
i understand how set attribute of item but i don't know how remove or add item from scrollList
void InkjetMenuView::paramScrollUpdateItem(RecordInkject& item, int16_t itemIndex)
 switch (itemIndex)
		case 0:
			item.updateTextParam(T_PVFIRE);
			item.updateTextValue(IPLINK_HeadData[headShow].vFire);
			item.setId(0);
			break;
i try to use
paramScroll.remove(item);
inside a function of scrollList but it doesn't work...
