heyo
Jan 16, 2024 11:28 AM UTC
Scroll animation
Does in the TouchGFX is scrollable container animation? I use doScroll() function but it would be nicer if it scrolls automatically with animation or smoothly.
Jan 26, 2024 10:22 AM UTC
Hello @heyo ,
Scrollable container does not provide a function for animation directly, however, you can use Easing Equations to calculate the deltas to have a smoother scroll. You can use a method similar to this:
#include "touchgfx/EasingEquations.hpp" //To have Easing Equations
//If new item is inserted, set the animationIsRunning to true
void Screen1View::handleTickEvent()
 if (animationIsRunning)
 scrollWithAnimation();
void Screen1View::scrollWithAnimation()
 const int duration = 50;
 if (animationCounter <= duration)
 int16_t delta = EasingEquations::linearEaseIn(animationCounter, 0, /* The final scroll value */, duration);
 scrollableContainer1.doScroll(0, delta); //If scrolling vertically
 scrollableContainer1.invalidate();
 animCounter++;
 else
 animationCounter = 0;
 animationIsRunning = false;
I hope this helps you!
Mohammad MORADIST Software Developer | TouchGFX
Hello @heyo ,
 animCounter++;
 else
heyo
heyoAuthor
Feb 2, 2024 11:40 AM UTC
Sorry but it's working like doScroll() function..
Feb 2, 2024 12:46 PM UTC
If you press insert new item rapidly, there might be a chance that the animation is not ended yet and the new item is added quickly. You have to allow the animation steps to end before adding a new item
