victagayun
Senior III
November 16, 2020
Run target on STM32H747I-DISCO failed
  • November 16, 2020
  • 5 replies
  • 1568 views
Hello
I am using graph on STM32H747I-DISCO. Running simulation is ok, like having the sine wave on it but when I click "Run Target" I get this error...
Run Target
 Generate
 Done
 Generate Assets
 make -f simulator/gcc/Makefile assets -j8
 Converting images
 Reading ./application.config
 Done
 Post Generate
 touchgfx update_project --project-file=simulator/msvs/Application.vcxproj && touchgfx update_project --project-file=../EWARM/TouchGFX.ewp
 Done
 Compile
 make -f ../gcc/Makefile -j8
 STM32CubeProgrammer is placed in Program Files
 Converting images
 Reading TouchGFX/application.config
 Linking TouchGFX/build/bin/target.elf
 Producing additional output formats...
 target.hex - Combined internal+external hex
 intflash.elf - Internal flash, elf debug
 intflash.hex - Internal flash, hex
 extflash.bin - External flash, binary
 Done
 Flash
 make -f ../gcc/Makefile -j8 flash
 Converting images
 STM32CubeProgrammer v2.5.0
 ST-LINK SN : 003100173137511539383538
 ST-LINK FW : V3J7M2
 Board : STM32H747I-DISCO
 Voltage : 3.23V
 Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
 2nd connect tentative with a lower frequency (8MHz)
 ST-LINK FW : V3J7M2
 Voltage : 3.23V
 gcc/Makefile:334: recipe for target '_extflash_' failed
 make[1]: *** [_extflash_] Error 1
 make: *** [flash] Error 2
 ../gcc/Makefile:50: recipe for target 'flash' failed
 Failed
 Failed
Best answer by victagayun
Yes, it is working on 2.5.0, see my previous answer (at the end)...
victagayun
Senior III
November 16, 2020
Any demo would display the same error...
victagayun
Senior III
November 19, 2020
I use on another PC with cubeprogrammer 2.6.0, here is different error.
Run Target
 Generate
 Done
 Generate Assets
 Converting images
 Done
 Post Generate
 Done
 Compile
 Converting images
 Done
 Flash
 Converting images
 STM32CubeProgrammer v2.6.0
 Error: External loader C:\Program cannot be loaded.
 Error: External loader Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\ExternalLoader\MT25TL01G_STM32H747I-DISCO.stldr cannot be loaded.
 ST-LINK FW : V3J7M2
 Voltage : 3.24V
 SWD freq : 24000 KHz
 Connect mode: Normal
 Reset mode : Software reset
 Device ID : 0x450
 Revision ID : Rev V
 Device name : STM32H7xx
 Flash size : 2 MBytes
 Device type : MCU
 Device CPU : Cortex-M7/M4
 Memory Programming ...
 Opening and parsing file: target.hex
 File : target.hex
 Address : 0x08000000
 Erasing internal memory sector 0
 Erasing memory corresponding to segment 1:
 Erasing internal memory sectors [0 1]
 Erasing memory corresponding to segment 2:
 Download in Progress:
 ±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
 ÛÛÛÛÛÛÛÛÛÛ 20%
 Error: failed to download Segment[2]
 Error: failed to download the File
 Hard reset is performed
 Failed
 Failed
previous error using another PC with cubeprogrammer 2.5.0 seems to be ok now.
Shripal_k
December 8, 2020
@victagayun​  I am also having exactly same problem when trying with STM32CubeProgrammer V2.6.0 on STM32H747i-Disco board. Can someone please provide any solution.
Run Target
 Generate
 Done
 Generate Assets
 Converting images
 Done
 Post Generate
 Done
 Compile
 Converting images
 Done
 Flash
 Converting images
 ST-LINK SN : 002B00453137510D39383538
 ST-LINK FW : V3J3M2
 Board : STM32H747I-DK
 Voltage : 3.23V
 Device ID : 0x450
 Revision ID : Rev V
 Device type : MCU
 File : target.hex
 ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 100%
 Failed
 Failed
Romain DIELEMAN
Could you download and try STM32CubeProgrammer 2.5 ? There are issues with the latest version 2.6 so we recommend to not use 2.6 until the next patch release.
/Romain
victagayun
victagayunAuthorBest answer
Senior III
December 8, 2020
