WDAI.1
Dec 10, 2019 2:59 PM UTC
Run simulator failed
Hi!
I was trying GFXdesigner and this happened to me, I tried different ways to find out the questions but no clue yet, it could be something wrong with the pictures? Then what should I do with them? Here is the detailed log:
Run Simulator
  Generate
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    Error: assets/images/Thumbs.db not supported by image converter
    generated/simulator/gcc/Makefile:225: recipe for target 'images' failed
    make[1]: *** [images] Error 1
    make: *** [assets] Error 2
    simulator/gcc/Makefile:32: recipe for target 'assets' failed
    Failed
  Failed
Looking forward to your answer!
Br,
Devin
userRobert
userRobertBest answer
Dec 10, 2019 3:29 PM UTC
Thumbs.db is Windows generated file. Just delete it.
userRobert
WDAI.1
WDAI.1Author
Dec 10, 2019 3:41 PM UTC
Thank you for your answer!
But I cannot find Thumbs.db in the folder, even if I viewed the hidden item.
Do you know where to locate it and delete?
Br
Devin
COSEBE
Senior
Dec 10, 2019 3:58 PM UTC
Look at touchGFX\asserts\images
thumbs.db shall be here
