Jtron.11
Senior
Oct 31, 2025 5:29 PM UTC
Repeat Button Implementation
Dear all,
Can you please help to point me to any of the repeat button implementation example?
I have successfully implement the single button with plus and minus but the number target is too big and it is taking too many clicks to get to the target number.  I would like to use the repeat button feature to achieve the goal that if the repeat button is holding, the setting will go faster and reach the goal.
MM..1
MM..1Best answer
Nov 1, 2025 7:37 AM UTC
Try search Long press
void Screen3View::handleClickEvent(const ClickEvent& evt)
 if(evt.getType()==ClickEvent::PRESSED && flexButton1.getAbsoluteRect().intersect(evt.getX(), evt.getY()))
 evaluate_long_press = 1;
 else if(evt.getType()==ClickEvent::RELEASED)
 evaluate_long_press = 0;
 Screen3ViewBase::handleClickEvent( evt);
MM..1
MM..1Best answer
