WLewe
Oct 24, 2019 1:43 PM UTC
Program not properly resetting FreeRTOS tasks.
I started off taking Method 3 from https://touchgfx.zendesk.com/hc/en-us/articles/205074561-Connecting-the-UI-to-your-system and it ran fine even after reset or power cycle. I added two FreeRTOS tasks to handle SPI2 and timer2. I flash the target board from inside TouchGFX by pressing Run Target. The board flashes fine and my program works as intended. However, when I reset the board or power cycle the device, my SPI and timer tasks do not run. However, the rest of the application runs fine. Any idea on what could be causing reset to break the program? I want to be able to reset or power cycle and still run my program.
WLewe
WLeweBest answer
Oct 25, 2019 8:44 PM UTC
We found the solution to the issue. It was due to improper initialization of SPI2. Once we reorganized the code and added in delays before SPI2, all of our troubles went away.
WLewe
WLeweAuthorBest answer
Martin KJELDSEN
Principal III
Oct 31, 2019 1:56 PM UTC
Hi @WLewe​,
Nice catch! Glad you sorted it out on your own. Sorry for the late response, i've been swamped! Will get back to a more normal-chaotic-situation next week i think =)
/Martin
