PSucr.1
Problem with background on Custom containers
When I have a custom container for a button which is the following. (Shown in order)
TextAre - which is update able.
Image - which is transparent in the middle under the Text.
Background - dark background.
When the custom contain for a button is displayed, the area to the left and right of the TextArea is the background of the holding screen, and NOT the background of the custom container.
This happens if the text is static, or if the text is updated.
Karan 123
Senior
May 14, 2020
Hi
Can you visualize what problem ? you are facing..
Please check above hope this helps...
Karan
PSucr.1
PSucr.1Author
Here is the TouchGFX custom container, and the output from a screen with 4 of the custom containers.
Notice below how to the left and the right of the text on each button, how the background is the Screen's background, and
NOT the buttons background.
PSucr.1
PSucr.1Author
Karan 123
Senior
May 14, 2020
Can you change the Button Image then try again ?
Here is my results...
Karan
PSucr.1
PSucr.1Author
My image is only a border, the internal of the border, is transparent.
So the text should appear on the imageBackground, but appears on the screens background.
Don't use a standard button, which is filled in.
PSucr.1
PSucr.1Author
I think I understand my problem, my image was the wrong image, and is this.
Which will cause this behavior. I thought I was using another image, which is only a border, and transparent center.
Karan 123
Senior
May 14, 2020
Ok Good​
