V.H
Senior
December 1, 2021
presenter pointer was NULL
The data read from Model class thru presenter in screen1View::screen1View() function was error. I debug the code and found the presenter pointer was NULL in constructor function.
Is it unsafe to use at constructor and destructor function time ?
GBert.2
Senior
December 6, 2021
I think you need to use the presenter screen after constructing your view object.
Did you try using it in the activate method?
V.H
V.HAuthor
Senior
December 8, 2021
That's how I use it now, because I can't track where the parameter is initialized.
