ALomb
Senior
Aug 30, 2019 8:46 AM UTC
PieChart Resize
I refer to the source code for "Model UI Demo 1 TouchGFX".
I would like to enlarge the PieChart, but I can't figure out how to do it.
In the GraphView::setupScreen function I modified the values for center, height and width.
// GraphView.cpp - GraphView::setupScreen
 pieChartX = 0;
 pieChartY = -16;
 donutX = pieChartX;
 donutY = 34;
 pieChart.setPosition(pieChartX, pieChartY, 300, 300); /* <- modified */
 pieChart.setCenter(150, 150); /* <- modified */
 pieChart.setPieChart(0, 0, 0, 0);
 pieChart.recalculatePieChart();
However, the PieChart radius does not change.
how to do ?
//Antonello
ALomb
ALombBest answer
Senior
Aug 30, 2019 9:06 AM UTC
Solved!
Calls to startPieChartAnimation method must also be changed (toMinRadius toMaxRadius)
//Antonello
ALomb
ALombAuthorBest answer
Senior
Solved!
//Antonello
Martin KJELDSEN
Principal III
Sep 2, 2019 8:23 AM UTC
Great. Glad you found that :)
/Martin
