IPrin.1
Mar 7, 2025 10:37 AM UTC
Pause or stop dynamic graph
I am trying to pause or stop a dynamic graph when data has scrolled to the right hand side once.  I will then use a second and third etc., dynamic graph on top to display further 'screen shots' of data, to create a stack of overlays.
Is it possible to stop the graph scrolling after a given time, or number of data samples?
Ian
GaetanGodart
GaetanGodartBest answer
Mar 10, 2025 10:46 AM UTC
Hello @IPrin.1 ,
The data will only scroll to the right if a new value is added.
I think that what you want is that if your graph width is 100 values, you want to show a total of 200 values so that it scroll to the right for a whole data's worth of length.
To do so you would simply have to add a number of data that is twice your graph's width (in terms of data points, not pixels).
Please find attached an example where I add 200 data points to a graph that can display 100 data points, with this amount of data, the graph scroll once to the right then stops.
I hope this helps!
If this comment answers your question, I invite you to select it as "best answer".
Regards,
Gaetan GodartSoftware engineer at ST (TouchGFX)
GaetanGodart
Hello @IPrin.1 ,
I hope this helps!
Regards,
IPrin.1
IPrin.1Author
Mar 13, 2025 10:10 AM UTC
Thanks so much, I was continuing to pass data to the graph causing it to continuously scroll.  All sorted now.
GaetanGodart
Mar 13, 2025 10:19 AM UTC
My pleasure, I am glad I was able to help you!
Regards,
