Senior
May 2, 2025 8:26 PM UTC
MVP base class moddified
Does anyone have an improved example to understand the MVP[1] (and widget/containers),
where you change the base implementation of the MVP ?
I was able to defined default implementation for the Model and the View but not for the Presenter or Drawables.
class ModelListener
public:
 virtual char* getPAmessage(eVerbose_t type) { return model->PAmessage; }
class View : public Screen
public:
 char* getPAmessage(eVerbose_t type) { return presenter->getPAmessage(type); }
The goal was to make a signal that is understood by every layer without having to use boilerplate at each new implementation of these interfaces.
 [1] Example: "Understanding Application Structure"
    May 5, 2025 6:38 AM UTC
    Hello @Marc_LM,
    This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
    Best regards,
    Maxime
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
