HNguy.21
MVP Application Error
Hi ST,
I have problem with MVP when applying BaseView for Views.
complier said cannot convert argument 1 from 'PresenterType' to 'T &'
Please help me fix the problem
Thank you.
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
June 9, 2020
Look for a project i shared on the community related to base-views.
/Martin
Alexandre RENOUX
June 9, 2020
Could you give more information on your issue ? Like source code ? What are trying to do exactly ?
/Alexandre
Martin KJELDSEN
Principal III
June 9, 2020
/Martin
HNguy.21
HNguy.21Author
The problems is solved. I inherrit wrong in Views -> it must inherrit Class View: public BaseView<ViewPresenter> instead.
Tks guys.
Martin KJELDSEN
Principal III
June 9, 2020
Great!
