shark
modify texts.xlsx
When Microsoft excel 2016 opens texts.xlsx, it will report some error. If I accept corrections and save the file, the designer can not recognize the file.
the text resource accumulates more and more, I must re-order the content. Which version or what other software should I use to modify the texts.xlsx.
shark
sharkBest answer
Based on previous check result, I solved it this way.
Copy an old texts.xlsx file from older 4.12 version, delete content in sheets, paste new content from current xlsx file, Save it. OK.
NOTE, table column order is different between version 4.12 and 4.13. so copy colums one by one.
hahaha
thank you, Martin.
shark
sharkAuthorBest answer
hahaha
thank you, Martin.
Martin KJELDSEN
Principal III
April 6, 2020
This just sounds so strange.
/Martin
