Charlie CHEN
Mar 11, 2020 8:07 AM UTC
MJPEG Example Problem
Is there someone has the experience about MJPEG with AVI format?
I have try the CubeMX Source Code from STM32H743-EVAL, but it won`t work.
I can display the First Frame and Second Frame, but after that it will keep showing this two Frame till the AVI is all parsed.
The source code include AVI Parser,Decode with DMA then DMA2D to LCD panel, it seems right for AVI & Interrupt Priority, so I`m not sure others is correct or not.
Hope someone can help!
Really appreciate!
