GMair
Apr 6, 2023 1:24 PM UTC
method for getting RGB values of touchpoint
is there a method to get the RGB value of the touchpoint of the display?
And if not how would a workaround look like?
Thanks and Best regards
Gerd
Osman SOYKURT
Osman SOYKURTBest answer
Apr 11, 2023 9:52 AM UTC
Hello GMair,
This question has been asked and a solution was suggested in this thread.
Hope it helps :)
/Osman
MM..1
Apr 6, 2023 5:51 PM UTC
I mean not from TGFX. It only renders objects in sequence. After rendered is pixel unknown.
You need read it from framebuffer directly.
Osman SOYKURT
Hello GMair,
Hope it helps :)
/Osman
GMair
GMairAuthor
Apr 13, 2023 12:49 PM UTC
Hello Osman, MM..1
thank you guys for the info.
BR
Gerd
