alpesh
Mar 29, 2019 11:31 AM UTC
Maximum camera and LCD resolution supported by STM32F controller
How much maximum camera and LCD resolution supported by STM32F controller ? can you please provide calcution for the same? Also suggest suitbale LCD and Camera module part#?
S.Ma
Principal
Mar 29, 2019 12:15 PM UTC
Hard to answer. You need enough
Ram for the frame buffer. Your display and camera minimum pixel clock will shortlist the candidates. Then check the package interface and pinout. Check how much ram flash and mips you need for the rest of the application
alpesh
alpeshAuthor
Mar 30, 2019 8:50 AM UTC
Is there any calculation for RAM requirement calculation using Pixel clock or resolution?
alpesh
alpeshAuthor
Mar 30, 2019 8:51 AM UTC
@S.Ma​
S.Ma
Principal
Mar 30, 2019 5:17 PM UTC
How to you drive the display?
Does the display has its own frame memory and you only need to update it when needed?
Do you plan to show videos? Frame rate?
What resolution and what interface? 8 bit parallel, 24 bit, 16bit, DSI?
It's difficult when specs of used components are so vague....
