Senior III
Feb 10, 2026 8:34 AM UTC
Keep one translation for each language
I have some text that should not be translated.
If a translation field in the table is empty, is there a way to make it automatically display the text from the first translation box, instead of having to copy and paste the same text into every box?
Osman SOYKURT
Osman SOYKURTBest answer
Feb 12, 2026 3:57 PM UTC
Hello @nico23 ,
Thanks a lot for your message, I discussed it with our team and we'll take that into consideration for a future release (I can't guarantee it will be in the next one though). I'll get back to you when I'll have more info concerning this.
unsigned_char_array
Lead III
Feb 10, 2026 9:00 AM UTC
You can export to excel, edit, then import. This may be quicker than editing it via designer.
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
nico23Author
Senior III
Feb 10, 2026 9:39 AM UTC
Yeah, the idea was to skip all of that. I was asking if TouchDesigner already does it without copy-paste or fancy scripting that elaborates the file. Just write once,a nd it automatically picks the one translation if an empty field is found.
Osman SOYKURT
Hello @nico23 ,
