manto.1
Dec 9, 2022 6:47 AM UTC
Issue with importing translations into TouchGFX!!!
I sucessfuly exported texts.xml with translations.rb
but when I try to import .xlsx back to .xml. I get the error sheet Typography not found!?
> translations.rb import texts.xlsx texts.xml
sheet 'Typography' not found
An error occurred during translations import!
Bellow are the files used
ferro
ferroBest answer
Lead
Feb 6, 2023 4:32 PM UTC
Could not be the problem in swapped .xml and .xlsx extentions in your command ?
Here is what my system shows:
0693W00000YA557QAD.pngAlso, my conversions run without .xsd file present.
Romain DIELEMAN
Dec 9, 2022 7:33 AM UTC
Could you share which TouchGFX version you are working with ? Are you sure you are working in the correct folder/path ? (since the error message says that it cannot find Typography tool)
/Romain
manto.1
manto.1Author
Dec 9, 2022 8:03 AM UTC
I copied the texts.xml and texts.xlsx to the folder where TouchGFX is installed where the translations.rb file is:
(..\TouchGFX\4.20.0\touchgfx\framework\tools\textconvert)
Then I run the command:
ruby translations.rb import texts.xlsx texts.xml
manto.1
manto.1Author
Dec 9, 2022 7:34 AM UTC
I am working with TouchGFX 4.20.0
manto.1
manto.1Author
Dec 9, 2022 7:42 AM UTC
manto.1
manto.1Author
Dec 9, 2022 8:06 AM UTC
manto.1
manto.1Author
Dec 12, 2022 2:27 PM UTC
Found the solution.
It is necesary to copy also the texts.xsd file to the path. This was not clearly specified in the documentation.
https://support.touchgfx.com/4.20/docs/development/ui-development/touchgfx-engine-features/texts-and-fonts
ferro
ferroBest answer
Lead
