GMeur
Feb 14, 2019 10:26 AM UTC
Is there a way to resize the widgets through the GUI designer?
I find it very inconvenient to have to change the png picture to resize my widgets (buttons, sliders, …). Is there a way to resize them from the same png picture (if there is one, couldn't find it…) ? If not, is it a function that will be introduced in the future ?
Thanks.
Martin KJELDSEN
Principal III
Feb 14, 2019 1:08 PM UTC
Hi @GMeur​,
It's been requested before but it's not something we want to do because the background for the button, for instance, may be complex and you would need to scale it which may ruin the graphics. Maybe in some cases where you had a simple background you'd be able to resize it without noticeable artifacts. I think it's a feature you'd mostly use for prototyping, where as for real products you'd have your graphics artists create exactly the graphics that you need (which would give the button it's correct size).
Does that make sense?
Best regards,
Martin
