Xzhiy.1
Jul 15, 2022 1:22 PM UTC
Is ListLayout in ScrollableContainer has ability to identify one of drawables added before, means to find out which drawable was clicked and transfer click event to that drawalbe ?
I read some demo code, the result is YES. am I right?
Yoann KLEIN
Yoann KLEINBest answer
Jul 18, 2022 8:17 AM UTC
Hello @Xzhiy.1​ ,
That should be totally doable.
You can get inspiration from the Scroll List & Wheel Example available in TouchGFXDesigner.
This example shows how to change a Bitmap, based on clicks on items inside a ScrollList or ScrollWheel.
In your case, you are using a ScrollableContainer and a ListLayout, but the same methods and attributes should be available, maybe just with another name.
Let me know how it's going,
/Yoann
Yoann KLEINST Software Developer | TouchGFX
Yoann KLEIN
Hello @Xzhiy.1​ ,
/Yoann
Xzhiy.1
Xzhiy.1Author
Jul 18, 2022 11:38 AM UTC
Thank you, Yoann KLEIN,
That is very good design for me to write code easy, only focus on callbak of drawables, NO need to find out which is pressed by myself, your answer make me clear about that.
