Zwei.9
Aug 29, 2019 8:11 AM UTC
Is it possible to draw a double precision graph?
I would like to make a very high precision graph for application in the field of optical fiber
Martin KJELDSEN
Principal III
Aug 29, 2019 8:19 AM UTC
Could you elaborate what exactly it is you need? You only have the pixels determined by your display to represent your values. We try to be as "precise" as possible with that in mind.
/Martin
Zwei.9
Zwei.9Author
Aug 29, 2019 8:33 AM UTC
For example, store 10,000 data points on a screen 100 pixels long.
Ozone
Principal
Aug 29, 2019 8:49 AM UTC
I think you mix up thing that have nothing to do with each other.
"Double precision" relates to the underlying data.
A display has only discrete pixels. Like integer.
If you get that, patent it and be filthy rich.
