MWetter
May 19, 2022 9:31 AM UTC
Is it possible to configurate the LTDC to Data Enable Mode?
Hello everyone,
is it possible to use a display that only supports Data enable mode?
If yes, how to configurate the LTDC for this mode?
I use the STM32H7B3-dk board and already modified the display. I connected a display that supports the DE Sync mode, but I have another display that only supports DE mode.
The LTDC documentation does not help.
Thank you very much
MM..1
May 19, 2022 12:41 PM UTC
I mean LTDC generate normal DE signal. If LCD work only with it you can use it.
Maybe HSYNC VSYNC can help over some NANDs...
MWetter
MWetterAuthor
May 19, 2022 12:52 PM UTC
Thank you very much. I will try it out and hopefully it will work :)
