ferro
Lead
Nov 23, 2023 3:17 PM UTC
If possible, how can be anti-aliasing disabled/enabled ?
Dec 6, 2023 1:19 PM UTC
Hello @ferro ,
No, TouchGFX does not have an option to switch Anti-Aliasing. It is mostly hardware related whether the hardware supports it or not. But, you can disable Dither Algorithm to save up space if you want.
Good luck
Mohammad MORADIST Software Developer | TouchGFX
Hello @ferro ,
Good luck
