Ebun.1
Senior
May 19, 2021
I want to know the X and Y coordinates when the button is pressed
Thank you for helping.
At the event of pressing the button of the view class
Is there a way to find out the touched X, Y coordinates?
Thank you.
Alexandre RENOUX
Alexandre RENOUXBest answer
May 20, 2021
Hi Ebun.1,
You cannot do that simply like this.
I would highly recommend you to use handleClickEvent() function and do something like :
void Screen1View::handleClickEvent(const ClickEvent& evt)
 if(button1.getAbsoluteRect().intersect(evt.getX(), evt.getY()))
 if(evt.getType() == ClickEvent::PRESSED)
 //retrieve x, y with evt.getX()/evt.getY()
 //Do whatever you want, you can even call other functions
 Screen1ViewBase::handleClickEvent(evt);
/Alexandre
Alexandre RENOUX
May 20, 2021
Hello Ebun.1,
You simply need to implement the handleClickEvent() function in your view to receive the click events.
 touchgfx_printf("Cooordinates of the click event : x = %d/ y = %d\n", evt.getX(), evt.getY());
When your question is answered, please close this topic by choosing Select as Best.
/Alexandre
Ebun.1
Ebun.1Author
Senior
May 20, 2021
Hi Alexandre RENOUX
I have an interaction when the button is pressed.
How can I get x and y in this?
Screen1View :: pushedButton ()
 // get x, y
Alexandre RENOUX
May 20, 2021
Hi Ebun.1,
/Alexandre
Ebun.1
Ebun.1Author
Senior
May 20, 2021
Hi Alexandre RENOUX
I am always grateful for your help.
It's not easy, isn't it?
Thank you for your answer.
lagari
September 8, 2021
Could you please explain your solution a little more clearly? I am having the same problem.
September 8, 2021
The example looks to be pulling the X and Y coordinates at the event, then determining if those are within the boundaries of the button image on the screen, and then allowing you to take a specific action. If you want to remember the X,Y coordinates save them in a variable or class where you can get at them later, or pass them to a processing function.
Ebun.1
Ebun.1Author
Senior
September 8, 2021
Hello.
I wanted to know the raw value before the coordinate transformation, so
I decided to save the coordinates in a global variable in BSP_TS_GetState () and use it.
MJohn.10
September 9, 2021
Hey,
you can try this one too, hope it may works for you.
OnTouchListener mOnTouch = new OnTouchListener()
 @Override
 public boolean onTouch(View v, MotionEvent event)
 final int action = ev.getAction();
 switch (action & MotionEvent.ACTION_MASK) {
 case MotionEvent.ACTION_DOWN: {
 final int x = (int) ev.getX();
 final int y = (int) ev.getY();
 break;
And if its works and you already got one please mention it too. Thanks.
