ST Migration account
ST Community Manager
Aug 22, 2026 5:02 PM UTC
I want to Get SVG ID
This account only shares restored community content posted by members between May 22 and June 9, 2026, who did not register for the new community.
Is there a function to get the currently set ID in the SVGImage widget?
Osman SOYKURT
Osman SOYKURTBest answer
Oct 6, 2026 1:36 PM UTC
We have added this new function in our API in the latest version of TouchGFX 4.27.0.
Aug 22, 2026 5:04 PM UTC
Hello .
Currently, such a function is not implemented. However, based on your request, I will implement it targeted for TouchGFX 4.27.0.
In the meantime, you can implement it yourself quite easily by modifying the SVGImage.hpp file, since the TouchGFX widgets are open source. You can find the file here in your TouchGFX project:
  • Simulator project: touchgfxframeworkincludetouchgfxwidgetsSVGImage.hpp
  • Hardware project: MiddlewaresSTtouchgfxframeworkincludetouchgfxwidgetsSVGImage.hpp
The framework files will only be overwritten or regenerated if you manually delete them, so the change will persist.
You should implement this function in the public section of the SVGImage class:
uint16_t getSVGId() const {
return svgId; }
Best regards,
Johan
Osman SOYKURT
