skydiveh
Sep 24, 2022 6:19 PM UTC
I Want to connect the 32STMF446 with the GFX01M2 display. According to ST it works, but to declare it in TouchGFX so that I can use it?
MM..1
Sep 25, 2022 7:32 AM UTC
If you ask one click choice solution = NOT EXIST
GFX01M2 is normal SPI LCD extension, then you need create new project for you STM, and add TGFX custom config.
skydiveh
skydivehAuthor
Sep 25, 2022 9:03 AM UTC
Thanks,
But how do I get to this choice. Always only the prefabricated boards.
MM..1
Sep 25, 2022 10:28 AM UTC
Open CubeIDE click start new project STM32 , select your MCU for custom boards or choice used board F446, configure all peripherals and add software package TouchGFX ...
For other IDE (Keil,IAR...) use CubeMX instead.
